UDP inbound connection
K0AY
Post by K0AY »
Yesterday, I started up V2. The program opened normally but all the user settings were all unfilled. I filled them all in but am having problems with UDP connections. WSJT-X complains:
error message client exception message format UDP server 127.0.0.1:2237
In the user's guide, I have copied the top entry on the left box. I think that should be the only entry to receive QSOs from WSJT-X.
Suggestions please.
on6at
Re: UDP inbound connection
Post by on6at »
Hello K0AY,
Look on the manual on page 168.
wsjt-x UDP.jpg (80.59 KiB) Viewed 1409 times
Maybe this will help.
73 Patrick ON6AT
Member UBA-IPA
WCA: ON-01354
K0AY
Post by K0AY »
Patrick...
Many thanks for your help. When I type in the entry as shown in the user manual the press the + at the right, nothing gets transferred to the box below as shown below. Interesting that my user manual stipulates [UDP_INBOUND] {JTMESSAGE[ 2237] WSJT DIRECT however I have the same problem that pressing the+ on the right does not transfer the entry to the box below.
on6at
Post by on6at »
(1) Normally you have to enter your port number first.
(2) Then give a name to that connection and (3) then type the service.
When that's all done, (4) press the plus (+) sign.
If everything was entered correctly, you should see entered data in the bottom box at UDP Inbound connections.
This is how I did it in version 2.17.0.0
73 Patrick ON6AT
Member UBA-IPA
WCA: ON-01354
