Hi all, my current configuration is:
IC7300 connected to a PC with RS-BA1 and VSPE (remote station)
(IC7300 com port splitted and connected to two ports one for the RS-BA1 remote utility, the second one exposed through TCP server)
A PC with RS-BA1 and VSPE (local station).
In the local station, I'm using Log4OM that is connected to the radio through OMNIRIG (1.X).
RS-BA1 connected through remote utility
Omnirig connected to a Virtual Port on VSPE connected through TCP to the remote TCP server COM).
RS-BA1 is working correctly.
Log4OM is able to change the frequency of the radio (when I select a spot in a cluster) but is not able to read (in real-time) the frequency. It's able very few times during tx to read the value of the two VFOs, but it seems very random.
I tried to change the poll frequency and time out value, but nothing really change.
I'm quite sure that the VSPE configuration is OK because RS-BA1 is working well together with another contest log (QARtest) everything is working fine (set and ready frequency, band and mode).
I suppose the problem is Omnirig. I'm using the last stable version (1.x).
Can you help me with this?
Any suggestion?
73 de IU3MIK
P.S.:
I test hamlib too, but not way to make it work.
Problems with Omnirig & VSPE
Jump to
- News
- ↳ Country & Special Callsign file updates
- Log4OM v2
- ↳ FAQ
- ↳ General discussions
- ↳ User support
- ↳ Error reports
- ↳ Feature suggestions
- ↳ Country (LANGUAGE) Forum
- ↳ German language forum
- ↳ Spanish language forum
- ↳ Portuguese language forum
- ↳ French language forum
- ↳ Italian language forum
- ↳ Award Support
- Log4OM v1
- ↳ User Support
- ↳ Software Integration
- ↳ SDR & VSP
- ↳ Award support
- ↳ FAQ
- ↳ Error Reports
- ↳ Technical Information
- ↳ Send data to Log4OM
- ↳ Receive data from Log4OM
- ↳ Databases Etc.
