WinKeyer
iz2rlo
WinKeyer
Post by iz2rlo »
hello
winkeyer messages are not transmitted correctly.
I use Icom 7800 interface micro Keyer II
someone can help me.
Thanks Cris
Re: WinKeyer
iz2rlo wrote: 18 Nov 2021, 11:51 hello
Thanks Cris
Not transmitted correctly - How?
Sends end before beginning,
Sends it in Arabic
Does not send numerals
Sends Zeds instead of A's
A hint or two will help us to help you!
iz2rlo
Re: WinKeyer
Post by iz2rlo »
Hi
compiled the macros, the message goes into transmission,
but the message is transmitted incorrectly.
if the message is short example callsign and 5nn all ok,
if the message is longer it transmits first the end of the message then the beginning
Re: WinKeyer
Anyone else experience this because I have been trying for a few days and it works fine for me with very long macros?
However I am using a genuine K1EL Winkeyer so I am not sure what could happen with clone Winkeyers
iz2rlo
Re: WinKeyer
Post by iz2rlo »
hello
the problem is the micro keyer II,
now one flex radio works all
73 Cris
G4DDL
Re: WinKeyer
Post by G4DDL »
Hi
I have the same problem with winkeyer when interfacing via my Microkeyer2 and its internal winkeyer.
On longer messages it sends the first character and the last few and then the remainder of the message.
I will try with a "real" winkeyer and report back.
Hope that helps, I am very new to Log4OM so I'm still learning.
I have a seperate problem with my FTDX101MP and Hamlib (again via microkeyer2) which I will report seperately.
73 Mike G4DDL
