Adding columns to the database
ac9hp
Post by ac9hp »
I have some data column customizations I want to add to Log4OM2.
This will not impact any existing data but I want to run the QSO entries against the QRZ page and get some information and store it in the QSO record.
I just want to make sure that if I add a couple of columns, it won't break the application.
The alternative is that I could keep a separate table with the new data points and link them via perhaps the QSOID column.
Thoughts?
Thanks,
DE AC9HP
Re: Adding columns to the database
New columns but existing fields to the existing grids or to the SQLite database
ac9hp
Post by ac9hp »
To the mySQL database.
Be careful but if you know what your doing it should be ok, don't attempt this if your not FULLY experienced in MYSQL
