Hello to all friends users from the Log4OM,
Who can help me to configurate the Yaesu FTDX10 and the Log4OM ?
Which settings on the ftdx10 are the best to become no problems on CAT operations to the Log4OM software program ?
Looking forwerd for your reactions.
Greatings from Dirk
Call Pd0dna
Configuration Yaesu FTDX10 and Log4OM
Re: Configuration Yaesu FTDX10 and Log4OM
Use Omnirig and make sure that you download the latest rig.ini file which contains the FTDX 10 configuration
Read the Log4OM user guide if you dont know how
My new FTdx10 arrived yesterday, I just cant seem to get it to talk to Log 4 OM! I am going nuts
I opened up WSJTx and managed to configure it no problem, copied the settings across to Log 4 OM, but still cant get it to connect.
I have all the latest Omni Rig downloads...... so I cant think what else it could be..... would anyone be able to help???
If you read our user guide you will see several times an instruction that
A. Log4OM, Omnirig and WSJT must all be 'RUN AS AN ADMINISTATOR'
B. Do not select your rig in WSJT - SELECT OMNIRIG (Rig 1 or 2)
ok thanks for your response..... managed to get it going after shutting down the computer and program several times. Eventually the program opened and displayed the FTdx10 frequency etc
