1) how do you do when you receive a paper QSL from a SWL to confirm it ?
2) When editing a QSL in the "QSL Info" tab; by choosing QSL; the "Via" field defaults is to "Electronic";
how to make that we choose another default value (for example "Bureau")
2) In this tab, if you choose QSL, you have the following values in the "Via" field by default:
- Undefined
- Bureau
- Direct
- Electronic
Can other values be added ? If yes, how ?
Can these fields be renamed ? If yes, how ?
Thanks & 73
Management of the receipt of paper QSLs
Dan - F6FLU
https://F6FLU.org
https://F6FLU.org
Re: Management of the receipt of paper QSLs
Log4OM is not designed to record SWL confirmations and there is no mechanism in ADIF for that
There are special SWL logs available
thank you Terry I suspected a little
you have a link for this kind of specialized Log for SWL ?
thank you
thank you
Dan - F6FLU
https://F6FLU.org
https://F6FLU.org
Thank you Terry i will check it out...
Dan - F6FLU
https://F6FLU.org
https://F6FLU.org
Hi
and for other questions Terry an idea or future functions maybe ...
Dan - F6FLU
https://F6FLU.org
https://F6FLU.org
No it's not on our road map and requires too many deviations from the design
