Thank you for the FAQ regarding duplicating a station setup. I have not set up a second computer/rig yet, but I plan to.
I am sure this will work, up to a point, but...
I sync with LOTW. Will just copying the folder structure under "\appdata\Roaming\Log4OM2\" path to the second computer also allow the new installation to sync with LOTW without any additional fuss? I thought that TQSL used a unique certificate per computer. I am not clear how a second computer could work without setting up a second "location" officially with ARRL...?
Thanks,
Larry N8KU
two stations and LOTW
||Larry N8KU||
Re: two stations and LOTW
Providing you have installed TQSL with the appropriate cert it will work
