Yes found that with a single QSO the adif file will not import. Adding an extra dummy QSO and it imports okay. So a workaround in the meantime.
73 Ian VK1DI
Log4OM 2.18.0.0 don't import ADIF files
Re: Log4OM 2.18.0.0 don't import ADIF files
Yes I can verify this, thanks for spotting it
Hi'
Same problem here for 1 line ADIF.
Not a long name and it's simple N1MM export. All Used to be fine prior to 2.18.
I have unsuccessfully tried to import long, short, LoTW and even the log from log4OM V1. Nothing will import. I keep getting "not connected to a valid data base". This happens every time. please help.
Is this a new installation or have you been using log4om before?
Did you create a database?
Hi
Just come across the same issue - if there is just one entry in the ADI file then the import fails.
Is there any progress on a solution?
Tom
GM8MJV
Tom
GM8MJV
Yes, looking for the next release. As long you wait don't import 1 line ADIF files..
