Hi
I can not get the county info to display on the Info (F2) when I put a US Call , but can get the State, QTH, and address
Thanks and 73's
USA County
Re: USA County
Could be possible if this info is not provided by the service. I use HamQTH and it works if the
call owner provides this in his data.
Re: USA County
My county display is also working and I happen to use (currently) QRZ.com as my primary data source.
It is possible, as noted above, that the data may not be in the source's records and available for download.
- V2-2000_Main-UI-County_qrz.JPG (103.36 KiB) Viewed 2629 times
