Cluster send command not working
K2DJL
Re: Cluster send command not working
Post by K2DJL »
Having the same problem. Cluster command is not working. Does not show any of the pre-defined cluster servers. List will not populate to select them. Dan K2DJL
K2DJL wrote: 31 Jan 2020, 18:58 Having the same problem. Cluster command is not working. Does not show any of the pre-defined cluster servers. List will not populate to select them. Dan K2DJL
Dan,
What version of Log4OM V2 are you using?
K2DJL
Post by K2DJL »
Latest version 2.2.
K2DJL
Post by K2DJL »
I have also uninstalled and re-installed 2.2. Same problem. Dan K2DJL
Make sure you send to all servers if you have a localhost set as your primary.
HB9VQQ
Post by HB9VQQ »
Makes no difference, same problem
Flex 6600 - Spiderbeam
NN7D
Post by NN7D »
K2DJL wrote: 31 Jan 2020, 19:49 I have also uninstalled and re-installed 2.2. Same problem. Dan K2DJL
Dan, do you have TeamViewer installed? I will PM you to set up a remote session, if you are available.
Doug - W7DRM
K2DJL
Post by K2DJL »
Doug: I don't have TV installed. Dan K2DJL
NN7D
Post by NN7D »
Dan,
Can you post a screen shot of your Configurations, Cluster tab settings?
TeamViewer is a free program for non-commercial use.
Doug - W7DRM
NN7D
Post by NN7D »
I spend some time on the phone with Dan, on the issue of few if any Clusters were showing in the list of Clusters in the Cluster Management window, Connection tab. Dan had actually discovered why this was occurring just prior to the call. In the Configurations, Cluster tab, he had selected "Show User Defined clusters". Once he changed this back to "Show stable clusters", all the clusters were displayed in the Cluster Management window.
So, "Show User Defined Clusters" will ONLY show User Defined Clusters. Meaning those clusters which you have modified with changed Initialization Commands, or SSID, etc. Those clusters thus changed, appear on the Cluster Management, Connection tab with a Bracketed "U" in front of the cluster name. I learned something on this one!
Thanks Dan!
Doug - W7DRM
