country file download error
w9mdb
Post by w9mdb » 05 Mar 2020, 21:56
Country file download is failing for both LogOM and LogOMV2
LogOMV2 says 403 error -- forbidden....
de Mike W9MDB
Re: country file download error
Post by DF5WW » 06 Mar 2020, 09:34
Hello Mike,
thank´s for reporting. We will check. ;) ;)
73´s .. Juergen ... ALT-512 SDR (10W) , 50 m random wire at CG-3000 autotuner, Ailunce HS2 (20W and 5W VHF/UHF) to LPDA´s and different vertical´s ...
w9mdb
Post by w9mdb » 07 Mar 2020, 21:45
If I may suggest all the file downloads should download the file first and then replace the old file.
Sounds like it's removing the old file and then downloading the new one and if it's fails you're screwed.
Mike
VA3AG
Post by VA3AG » 07 Mar 2020, 23:46
w9mdb wrote:
05 Mar 2020, 21:56
de Mike W9MDB
Mike:
This was already fixed! Force the UG download to get it.
Aldo VA3AG
w9mdb
Post by w9mdb » 08 Mar 2020, 00:06
I know the download was fixed...I was suggesting the logic for downloading needs to change to avoid the problem of not having a country.xml file in case the download fails.
Mike
