DXCC "Phone" config missing in Awards Statistics
ac5aa
Post by ac5aa »
After last weekend's SSB DX contest I went to the Awards Statistics view to see if there were any new ones I needed to chase QSL's for. When I open the "Predefined config" dropdown under the DXCC award, "Phone" is missing from the list. I think all the other categories of the award are there, just no "Phone" selection. Now, I could have something wrong in my setup, but I don't think so. Scanned for other writeups on this and didn't find any, so thought I'd mention it here. Thanks in advance.
73, Duane AC5AA
Re: DXCC "Phone" config missing in Awards Statistics
ac5aa wrote: 11 Mar 2020, 18:07 After last weekend's SSB DX contest I went to the Awards Statistics view to see if there were any new ones I needed to chase QSL's for. When I open the "Predefined config" dropdown under the DXCC award, "Phone" is missing from the list. I think all the other categories of the award are there, just no "Phone" selection. Now, I could have something wrong in my setup, but I don't think so. Scanned for other writeups on this and didn't find any, so thought I'd mention it here. Thanks in advance.
Duane,
Until Danielle can get 'phone' entered in the pre-configured area go to Award Filters and select "phone".
That should work in the meantime.
You can also add it yourself in the award manager until it gets fixed.
Note that there is an issue where edits and deletions in award manager will be overwritten based on the scheduler that updates awards.
ac5aa
Post by ac5aa »
Thanks for the pointers, guys!
73, Duane AC5AA
No need to mess with the awards manager its already available
In View/award statistics select DXCC
In the drop down Predefined Config list select the empty space above 10m, this then disables all predefined awards
Now click on the 'Award filters' tab
Select the required filters like
Phone only
20m
date range
or whatever
Click the refresh button lower right and the filters are applied
This way you could export only QSO's relevant to any filtering you have selected by using the two export buttons on the top right edge of the awards window to an Excel or CSV file
kd0zv wrote: 11 Mar 2020, 18:44 You can also add it yourself in the award manager until it gets fixed.
I dont think this needs fixing at the moment because the facility is already available
But why is it missing in the predefined filters?
Yes, there are other ways to do it but all other modes are listed except phone.
Isn't the purpose of the predefined filters basically a quick menu for commonly used choices? I would think phone would qualify as common?
Got 'phone' in the award. Should be in next release.
As we've noted it is still available via filters ... as you already know!! ;)
4x1zq
Post by 4x1zq »
1. Is there a way to show "deleted only" ?
2. Is there a way to show "needed only" for DXCC award ?
Thanks and 73 de Avishay
4x1zq
