The statistics frame doesn't seem to track correctly.
I'm in the final "clicks" of 5BandDXCC, and need 10 clicks on 80meters to complete it.
I've been using the "statistics" frame to spot needs. This evening I heard EA6NB in the Balearics, and the statistics frame in "Main" showed EA6 as "worked but not confirmed" on 80M digital.
But when I went to EA6 "worked before", I have four LoTW confirmations on 80M digital confirmed.
To check this, I went to ARRL LoTW "Awards" page, and it shows EA6 confirmed on 80M.
Statistics don't track
Re: Statistics don't track
You are correct there is something wrong I just checked this and found the same
We will check this out meanwhile use the grid to the right at top
