Error uploading LOTW
ZP5RPO
Post by ZP5RPO »
Hi, I have received this error when trying to upload to LOTW:
INFO: ADIF File created successfully.
INFO: TQSL Version 2.5.7
No private TQSL Password set
Executing TQSL with upload
Messages from LOTW:
TQSL Version 2.5.7 [v2.5.7]
No se pudo encontrar la ubicación de estación seleccionada
Final Status: Command Syntax Error(10)
Command syntax error
LOTW END
Re: Error uploading LOTW
Wrong TQSL setup. You have no Station Location defined or the used Station Location
was not found (maybe a type error in your settings). Check in TQSL what you have
setted up there. Check that upper and lowercase letters are correct.
ZP5RPO
Post by ZP5RPO »
Hi Juergen.
Thanks for answer, I think is OK my location:
Think the problem isn´t a Log4OM related problem. Your station location has 2 empty spaces and
a "-" inbetween. Try to change your station location in TQSL to maybe "Asencion" and if this one
is setted up use the same in Log4OM settings for the LotW upload. Don´t use special characters
but upper case and lower case must be identical that TQSL working correctly.
ZP5RPO
Post by ZP5RPO »
Juergen.
I have changed the location to "Asunción" and the same error apears, in the version 2.9.0.0 the location "ZP5RPO - Asunción" worked fine.
Do your zones in TQSL match the zones on your LOTW profile on the LOTW website?
ZP5RPO
Post by ZP5RPO »
Hi Terry.
THis is the info I have found in the website of LOTW
LOTW cert.jpg (36.18 KiB) Viewed 3731 times
I can upload manually the adif of my new QSO's.
ZP5RPO wrote: 27 Nov 2020, 02:36 I can upload manually the adif of my new QSO's.
By using TQSL?
ZP5RPO
Post by ZP5RPO »
Yes by using TQSL
LOTW upload.jpg (83.61 KiB) Viewed 3714 times
OK What you need to do is this
1. Set Log4OM to TRACE MODE in the help menu
2. Attempt a Manual LOTW upload from Log4om using the QSL manager
3. Complete a support request from the help menu, please check the box include ADIF
4. Email the support request zip file to me at g4pop (at) arrl.net with a reference to this forum thread
Note:
Do not restart Log4OM after you set trace mode or the program will default back to info mode
