Logging 60M QSO Issues
W1SMC
Re: Logging 60M QSO Issues
Post by W1SMC »
I first made certain the bands were selected correctly in the settings/program configuration/user preferences menu. And they were.
Then I updated a copy of the bandplan_dxcc291.xml, added a set of XML entries for the CW frequencies and tried my test case again.
I still have the same issue.
My next move would be to uninstall and reinstall the product.
Before I do this, can anyone in Region 2 confirm they are having the same issue as I am? If no one is having the same issue with logging 60M QSO's then it would have to be I hosed something somewhere in my configuration.
Either way, I can't see how any US station logging a CW or USB 60M QSO for that matter would not have an issue with the bandplan_dxcc291.xml file.
To get the QSO into the database I had to manually select the 60m band and then press Enter. And even then, when I view the QSO using the Edit QSO dialog the Band and RX Band fields are empty for ONLY 60m QSO's.
Thanks Terry for your support.
W1SMC
Post by W1SMC »
I have confirmed via N1FG that he has no issue logging 60M QSO's.
He is sending me a copy of his bandplan and I will try again ....
I'll keep y'all posted .....
W1SMC
Post by W1SMC »
Ok I did get things to work successfully ....
My first two attempts at changing the bandplan_dxcc291.xml file were incorrect.
My friend Larry, N1FG, provided a correct bandplan_dxcc291.xml file that works correctly.
I have attached the file he provided.
(10.37 KiB) Downloaded 140 times
W1SMC wrote: 27 Aug 2021, 10:39 Ok I did get things to work successfully ....
To avoid the file being overwritten on next program update insert under score user like bandplan_r2_ user.xml
