new TCI released and issues with EESDR 3
iu4jnr
Post by iu4jnr »
Hi all,
Expert Electronics in their EESDR 3 V 0.9.0 released the new TCI, version 1.6.
This version is different from the one supported in Log4Om and for those using it with the SunSDR series, it causes a small yet annoying issue:
Clicking on a spot from the Log4OM cluster list, the EESDR software correctly switch to the frequency, however, if the new frequency is outside the panadapter window, the zoom won't follow making the TX/RX filter disappear. in few words, it loose the focus on the actual frequency.
The solution would be to update the LOG4OM to TCI 1.6.
Max IU4JNR
Re: new TCI released and issues with EESDR 3
iu4jnr wrote: 13 Sep 2021, 16:32 Hi all,
Max IU4JNR
Max,
I've added this to the Mantis list for resolution. Tnx for input.
I'll check...
unfortunately i've my ham radio shack packed due to some homeworks, i'll try to check if it's an easy fix
