data settings lost
do9sms
data settings lost
Post by do9sms »
Hi @ all, after every new start of Log4OM I have to renew all datas, station information, external services, user preferences, simply all that, what you set up at a new configuration... thats soooo bad and boring... whats my mistake, what could be the issue??? any sollutions???
tnx in advance, vy 73 de Uwe DO9SMS
Re: data settings lost
Uwe,
When you installed Log4OM did you let it select it's own folders/directories or did you tell it to use a different location?
It is likely that you have the base config files in a locked/secure folder that may not be accessible during start of Log4OM.
do9sms
Post by do9sms »
Hi Nolan, there ist just one folder what I create for the installation...
do9sms
Post by do9sms »
Nolan, today the start was ok... the only thing what was different, is the mode... I closed yesterday in FT8 mode and after the restart today, the mode is USB...
do9sms wrote: 22 May 2022, 14:09 Hi Nolan, there ist just one folder what I create for the installation...
Uwe,
Your comment tells me that you did not let Log4OM install to it's normal default folders.
By creating your own folder to put the basis of the program in will cause all manner of issues.
Now ... in that regard there are two version of Log4OM for an OM to install.
1) Standard version
2) Portable version (used most often for a thumb-drive, etc..
Which of the two installation packages did you select, download and install?
What version of Log4OM have you installed?
do9sms
Post by do9sms »
Hi Nolan, Standard Version 2.21.1.0
do9sms
Post by do9sms »
Well, after 4 times new installation I have to accept, that the issue is still activ... no solution... :cry:
After entering all information in the settings procedure did you forget always to hit "Save config" ?
Where are the user files stored on your PC, path please?
