pst rotator
Re: pst rotator
no funziona completamente .
Re: pst rotator
Try deselecting "UDP Control". I do not think it is necessary. I do not have this selected in my config.
73 Peter G3ZSS
Re: pst rotator
grazi a tutti il problema risolto o dovuto cambiare i parametri pst rotator
.73 rosario
.73 rosario
Re: pst rotator
Tnx Peter!
G3ZSS wrote: ↑20 Jan 2020, 14:04 If you are referring to this overlay map in PSTRotator
Then I created the map by using a programme called Aziworld by F6DQM. You should be able to quickly find it by searching the web. Save the map as Azimuthal.bmp and place this file in the folder \PSTRotatorAz\Maps\
Hope this helps?
Rigs: FLEX-6300 Ant: 6 band hexbeam (by SP7IDX).
http://m0pkz.co.uk/
http://m0pkz.co.uk/
