Website update option. (online log)
Posted: 25 Jan 2020, 18:13
by pd1ahm
The Log4om v2.1.0.0 is very good and pleasant to work with.
So my congratulations to the people who made it, I'm very happy with this fine update.
Still I have 1 question, is there a possibility to generate an online log in v2 like in v1.xx?
I can't find the website update option.
73 and thanks for this great update!
Hans
Re: Website update option. (online log)
Posted: 25 Jan 2020, 18:15
Yes you do will find it documented in the user guide
Posted: 25 Jan 2020, 20:53
by pd1ahm
The only thing I could find is for pages like QRZ, LOTW, but I mean for my own webpage.
In the 1.3xx version generate Log4OM a local log-webpage and uploaded it to my own page.
That I can't find that in the documentation.
73 Hans
Posted: 25 Jan 2020, 23:39
by KI5IO
pd1ahm wrote: ↑25 Jan 2020, 20:53
73 Hans
Hans,
Check out Page 116 in the Users Guide. ADIF Post is the title that may be what you are looking for.
Posted: 26 Jan 2020, 10:11
by pd1ahm
Hi Nolan,
Thank you for the tip.
ADIF post Log4OM is able to send a POST/GET message to an external website, passing custom parameters and required payloads
But unfortunately it is not the solution I was looking for. The previous versions had a generated webpage with an .html output. You can put this easely on your own webpage.
73 Hans
Posted: 31 Jan 2020, 19:11
by pd1ahm
Tnx for al the tips!
I'm so sorry but it didn't help me. I made a print-screen of the old v1 version.
- html-log.jpg (80.5 KiB) Viewed 4032 times
I can't find a way to do this with the ADIF files.
73 Hans
Posted: 10 Jun 2020, 05:01
by VK4FI
I am also very interested in this, have we got a solution yet??
Posted: 10 Jun 2020, 11:01
by VK4FI
Ok so I really hope that this can get resolved and we will be able to create and upload a HTML generated page as was the case in V1.
In the mean time as a work-around for those like myself who can't or do not want to use the ADIF post and PHP I did the following.
I reinstalled V1 of the program and then setup to log from V2 to V1 as described in the Manual on page 156.
Once this is setup, as you record a entry in the V2 logbook it is also logged in V1 and I then setup V1 to publish page as before.
Bit of setup but once done all good.
Take a look at
http://www.vk4fi.net.au/logbook.htm
