Problem to insert mode
F1ABL
Post by F1ABL » 26 Jan 2020, 09:55
If i want to insert a contact manually, when i'm in mode i don't have the whole list.
I only have a limited choice, for example I cannot choose the PSK31 mode.
Do i have a problem i'm using v2 v2.1.0.0
73 Michel
F1ABL Michel JN24of
Re: Problem to insert mode
Post by DF5WW » 26 Jan 2020, 10:06
Hello Michel,
go to the program configuration and hit "User Preferences" You will find a band and a modelist
where you can check/uncheck the bands/modes you need or not.
73´s .. Juergen ... ALT-512 SDR (10W) , 50 m random wire at CG-3000 autotuner ...
HB9VQQ
Log4OM Beta Team
Post by HB9VQQ » 26 Jan 2020, 10:06
Bonjour Michel,
this depends on your settings in Program Configuration --> User Configuration --> User preferences -- > Preferred modes.
Roland
Flex 6600 - Spiderbeam
HB9VQQ
Log4OM Beta Team
Post by HB9VQQ » 26 Jan 2020, 10:07
Juergen was some seconds quicker :-)
Post by DF5WW » 26 Jan 2020, 10:19
Better 2 replies then no one, HI ... :D :D
F1ABL
Post by F1ABL » 26 Jan 2020, 10:34
Thanks Roland, thanks Jurgen all is ok
73 michel
F1ABL Michel JN24of
