Good morning. I have updated to version 2.3.0.0. and I noticed that the alert doesn't work. In previous versions it was OK.
73 - Felice, IZ8FFA
Alert don't running in the 2.3.0.0 Version
Re: Alert don't running in the 2.3.0.0 Version
same problem here, even into 2.4.0.0 is still not working, what can be the reason??
I see the RED alerts into the cluster screen but no sound.
If i test it into the cluster config screen all seems to be OK
greetings
Luc ON7KZ
greetings
Luc ON7KZ
In both cases it seems that you might have the alert incorrectly set up
