Distance
Distance
I uploaded a small adif from N1MM this weekend, updated the bio which nicely populated the grid ref.....but the distance stays as 0. Is this correct?
Rob
HB9ETR / G0IFL
K3/Win4K3Suite/OnmiRig/L4OM v2.31.0.0
Win10 i7-6700
HB9ETR / G0IFL
Win10 i7-6700
Re: Distance
N1MM does not calculate distance so zero is correct
We should probably add a calculation to do that, will put it on Mantis
Re: Distance
but N1MM did not add the grid ref...L4OM did when I refreshed the bio
Rob
HB9ETR / G0IFL
Win10 i7-6700
HB9ETR / G0IFL
Win10 i7-6700
Re: Distance
Hi Rob,
can you check that your grid is also updated if you do refreshed the bio ? The field is called "My Grid Square".
If this is empty Log4OM can´t calculate the distance so both grids are needed ...
Re: Distance
correct, the reference is blank.
the station details have been filled in during initial config.....but on the edit QSO page, most details have not transferred (including grid ref, op callsign, address details etc)
Rob
HB9ETR / G0IFL
Win10 i7-6700
HB9ETR / G0IFL
Win10 i7-6700
Re: Distance
What you can try at the moment is to use a filter in QSOMgr which showing you all contacts with an empty
"My Grid Square" field. Filter is "MyGridSquare " "SMALLER" "AA00AA" and hit the + icon. Now all your contacts
will be listed which have an empty "My Grid Square". Now you can select the contacts you like to bulk editing
and give them your original Grid.
If done so and V2 has been updated all contacts which including both locators should show a calcilated
distance (i hope).
distance (i hope).
Re: Distance
i followed your guide and it did bulk edit correctly.....but the distance still didn't calculate
Rob
HB9ETR / G0IFL
Win10 i7-6700
HB9ETR / G0IFL
Win10 i7-6700
Re: Distance
Was only an idea .... By the way, have you restarted V2 after the bulk update ? Or used the refresh button ?
B.t.w. i don´t work with N1MM so i can´t test on my side for this.
Re: Distance
yes, re-booted program but same-same
thanks for trying
thanks for trying
Rob
HB9ETR / G0IFL
Win10 i7-6700
HB9ETR / G0IFL
Win10 i7-6700
Re: Distance
Not a problem but we´ll try to find out anything .....
A last try, can you do another manual lookup for one of those N1MM contacts which provides
now your own locator ? Only a test ...
