My station log has several callsigns, 2E0, 2D0, 2M0, MD3 and /P etc. On V1 I used different profiles for each callsign and swapped profiles as required. Each callsign is stored as the station callsign with Owner and Operator remaining the main 2E0.
HRDLog upload fails when using something other than the main callsign with version 2 where I think it worked with V1. Can’t see any reason for the failure.
I also use LOTW and Clublog. Unlike HRDLog they each need special configuration to accept multiple callsigns but once done they work OK. Profiles in Log4OM works OK, but it would be better if there was a way to make the upload function aware of the desired callsign (from the station callsign field) rather than have to profile swap or change configuration.
External Services / Multiple Callsigns
Return to “General discussions”
Jump to
- News
- ↳ Country & Special Callsign file updates
- Log4OM v2
- ↳ FAQ
- ↳ General discussions
- ↳ User support
- ↳ Error reports
- ↳ Feature suggestions
- ↳ Country (LANGUAGE) Forum
- ↳ German language forum
- ↳ Spanish language forum
- ↳ Portuguese language forum
- ↳ French language forum
- ↳ Italian language forum
- ↳ Award Support
- Log4OM v1
- ↳ User Support
- ↳ Software Integration
- ↳ SDR & VSP
- ↳ Award support
- ↳ FAQ
- ↳ Error Reports
- ↳ Technical Information
- ↳ Send data to Log4OM
- ↳ Receive data from Log4OM
- ↳ Databases Etc.
