Microham III USB and Log4OM.
Posted: 22 Mar 2020, 10:41
by F4GJC
I wish to acquire an interface to decode and code digital modes.
Before purchasing, I would like to know which OMS use this interface?
If so, could you describe the configuration that you have put in place? (router, log4Om, etc.)
Thanks in advance.
73 Christian.
Re: Microham III USB and Log4OM.
Posted: 22 Mar 2020, 14:42
I use the g4zlp pro3 interface because it has the latest Winkeyer usb chip whereas the microham has the old serial chip which does not work with log4om Winkeyer support unless they have very recently changed it!
Posted: 22 Mar 2020, 14:59
by DF5WW
Hi Terry, using the same here but checked the Website of ZLP electronics
and can´t find the Pro 3 anymore. Looks like it´s out of production. Have
it also buyed to have full Winkeyer functions with Log4OM and different
contesting software.
Posted: 23 Mar 2020, 11:14
by G3ZSS
For what its worth, I have a Microham microKeyer III and it works fine with the integral Winkeyer. When I connect it says "hardware version 31".
Posted: 23 Mar 2020, 12:01
by DF5WW
Hi Peter,
the thread opener is referring to the Microham III USB interfacce:
https://www.microham.com/contents/en-us/d158_U3.html
not to the, much more expensive, microKeyer III
https://www.microham.com/contents/en-us/d126_MKIII.html
By the way, for the Digimaster Pro 3 i´ve payed around 170.- € including the needed cableset
for the transceiver. The Microham USB iii interface costs around 140.- € plus 72.- € for the
needed cable set. Pricing for the microkeyer III is around 399.- € plus the cost of 90.- € for
a needed cable set.
Posted: 23 Mar 2020, 12:08
G3ZSS wrote: ↑23 Mar 2020, 11:14
That is a USB version thats why it works
