N1MM Integration
Posted: 31 Mar 2020, 18:51
by K0HB
It appears to me (correct me if wrong) that if I configure for use of N1MM (which I use only in contests), that I will lose CAT control when I return to "normal" operation. Is that true?
If it is true, then I assume that I could build a new configuration, call it "Contest", and invoke it when I use N1MM. Then return to "normal" configuration when running without N1MM. Is that also true?
Re: N1MM Integration
Posted: 31 Mar 2020, 18:57
It's only a couple of clicks to restore CAT in Log4OM after your contest session so hardly worth setting up another config IMHO
Posted: 31 Mar 2020, 19:20
by K0HB
G4POP wrote: ↑31 Mar 2020, 18:57
Thanks, Terry, for the prompt answer.
I'll consider that as an option.
Meanwhile, is my "multi configuration" option described above a viable procedure?
Posted: 31 Mar 2020, 19:22
Yes it is but more effort but your choice
Posted: 01 Apr 2020, 00:23
by KD0ZV
So Terry, all the other settings can stay in place? You just need to enable/disable the cat?
Posted: 01 Apr 2020, 06:33
kd0zv wrote: ↑01 Apr 2020, 00:23
You might want to uncheck the UDP connection also if your going that route, but only to save a little CPU activity
Posted: 01 Apr 2020, 22:06
by K0HB
Terry, I've found another solution. It is described in a new thread.
