CAT Control with Xiego G90
Re: CAT Control with Xiego G90
I have problem with connecting also. Is there any solution for this?
I have one and connection via Log4OM/Omnirig is very easy. Use the Icom IC-7100 file in Omnirig
and check that all the Settings are o.k.. But know that this little Chinese Radio not show´s 2 VFO
frequencies ....
Mine is working fine with Log4OM and Omnirig.
Please check also this Thread from the Top (First Post): https://forum.log4om.com/viewtopic.php? ... G90#p34534
frequencies ....
Yes i hvae read quite many articles and topics but still i have no luck.
I am not sure if the cable is faulty or something is broken in the G90.
I hvae tried with older and newer Omnirig. Also FLrig, which got stuck and G90 doesn't reply. Tested also with HDSDR
I have also CE-19 now, but wsjt-x also doesnt seem to work with my G90...
Don´t have CE-19 and, as i said, all is fine here. I have CAT control via the connector at the
left side of the G90 and all is fine. By the way, there´s no "old and new" Omnirig. Latest
original is 1.19 from Afreet Software and V2 from Switzerland dosen´t work correctly.
