Solar
W3LI
Solar
Post by W3LI »
I would guess that many of us are looking at solar power. My contractor will use panels that have a Micro Inverter at each panel.
My question is has anyone heard of any noise being generated by these inverters.?
I believe that this is OT for most but I would like to know if anyone does know the answer.
Be Safe and Healthy, Andy... W3LI
SM6WET
Re: Solar
Post by SM6WET »
Generally it is not the panels but as you mention the inverters that causes issues with noise on the HF/VHF/UHF bands.
If you ask your installer what make and model he like to use you can probably google and find out if these are ok or crappy.
Usually the best are those with a true zine way but usually also quite expensive.
