Terry
V2 is stable enough for me to abandon V1. I use Revo Uninstaller to uninstall applications. If I uninstall V1, do I risk deleting any files used by V2? Both apps were installed in their default folders.
V1 uninstall
Re: V1 uninstall
No problem to uninstall V1. The config folders have different names so not possible to delete V2 files
with V1 deinstallation.
Re: V1 uninstall
I personally dont like uninstallers I just use windows add and remove programs, but hopefully it wont cause you problems because Log4OM 1 is a totally separate installation to V2
Re: V1 uninstall
Understood, but ... V2 uses the ADIF files (in the same folder that V1 used).
Using the Windows uninstaller, would it also uninstall the ADIF data files? Of course, I do have them backed up, just in case.
Re: V1 uninstall
No it leaves the user files alone but your choice
The V2 user files should be in a different folder unless you changed it
V1 uses a folder called /LogOM
V2 uses a folder called /Log4OM2
This is why its possible to run both programs at the same time
