Hello all,
I am having a problem uploading my QSOs made from my portable QRA.
It works well with my fixed QRA callsign, but the server does not recognize the user when I want to upload my portable QRA log. The uploaad code is correct.
The other accounts (LoTW, eQSL, Clublog, HamQTH) work well with the portable QRA.
It works well with an other log software.
Any idea to submit to me?
Thank you in advance.
73 F8BJE, Guy
Issue uploading to HDRLOG with portable QRA
Re: Issue uploading to HDRLOG with portable QRA
I think for HRDLog you need to add your /P call to your profile
Hello Terry, thanks for your reply.
I don't konw how to add my /P to my HDRLOG profil...
I found this topic on HDRLOP help :
http://www.hrdlog.net/docs/SpecialCallsign.aspx
How to do the same with Log4OM ?
PS : I don't whant to create a new log book with my F8BJE/P callsign, again, it worked with an other logbook software, I can list in the same HDRLOG profil my QSO made with both of my callsigns F8BJE and F8BJE/P
Hello Guy,
you don´t need to create a new logbook. You only need to add a new profile in Log4OM.
You can use the same database as in your main profile but you can use other upload
preferences for the new one. Only difference in the log will be that your station call
for the 2nd profile is stored as yourcall/P.
Check out the manual for multiple profiles.
Hello Juergen, thanks for your reply.
I did that
In the same SQL Lite database, I created 1 profil for F8BJE station and an other one for F8BJE/P station.
- Profil F8BJE works well with all externals services : LoTw, QRZ.com, eQSL, Clublog, HDRLog, HamQTH.
- Profi F8BJE/P works well with all externals services except HDRLog...
I did that
Why not give Claudio at HRDLog a shout, I am sure he will help you!
