E-QSL management....
Re: E-QSL management....
Version 2.8.0.0
Regards
Grant
Version 2.8.0.0
Regards
Grant
Has this worked in the past or have you never tried it before?
Exactly what steps are you taking to download the eqsl's
I am surprised you are having this problem because its not a problem that others have reported and having loaded a version of 2.8 its working faultlessly for me.
First time I am using this function. It has been a struggle. I use QSL Management tab then try and select the dates on the screen as I think appropriate and then hit the download button. The resultant text scrolls and tells me there is a contact recorded on eqsl but when I close that screen down, I don't see anything recorded in my log. There doesn't appear to be a tab to hit to update the log, save the download or even close the pop up screen. So I am guessing and using trial and error at this stage.
Are you waiting for the message that says the operation is completed before you close the download window?VK4JAZ wrote: ↑28 Aug 2020, 06:11 Hi Terry,
In Help/Log level set TRACE mode
Attempt another eqsl download and then send me the log file from the help menu - BY EMAIL TO THE ADDRESS SHOWN ON QRZ _ DO NOT POST THE LOG FILE HERE
Restart Log4OM
Thanks Terry,
I now have it working.
Regards
Grant
Regards
Grant
Hi terry,
I think I may have stumbled across the correct setting or something.
Grant
Grant
