Cluster slow start
K5CKS
Cluster slow start
Post by K5CKS »
I am wondering why the telnet cluster takes so long to load? 3 minutes after Log4OM is up and running this morning and still no cluster list. When I start Cluster Management and "Disconnect" it will flash the cluster for a second and then go blank again. I can restart the cluster and I see the spots in the management window but they don't appear in the Cluster window. I have no filters set. Anyone else seeing this?
Thanks & 73,
Rory, K5CKS
Re: Cluster slow start
You might try refreshing the Log4OM SOTA database from the Settings/update resources menu, I know you will find it hard to connect that to the cluster but there was a problem with the award file which resulted in the cluster spot awards checking to have to check thousands more entries than normal and this can cause a cluster time out or slow down the filling of the cluster grid.
K5CKS
Post by K5CKS »
Thanks for the tip! That seemed to have an instant effect. All good now.
Rory, K5CKS
WA2SQQ
Post by WA2SQQ »
I too was experiencing this delay.Terry, thanks for the tip, very much appreciated.
:D :D :D
