I am using 3 different screens here (actually 4 but the fourth is on another PC).
What is very good with Log4om is that you can detach the windows as you want.
For example on screen #1 I have the main window of Log4om (main tab)
on the second screen I have the cluster window and the JTDX window,
on the third screen I have the "Worked before" window.
So I organize my windows as I want and that's fine.
On the other hand, I have not found if we can save this environment.
I would like that when you quit Log4om all the positions of these windows are saved
and when I relaunch Log4om it automatically opens all my windows and on the different screens.
So I would like to find my environment as I left it
Is it possible ? I did not find how to do it
If not, would it be possible to consider this feature for a future version?
Thanks for your comments
Save your environment
Dan - F6FLU
https://F6FLU.org
https://F6FLU.org
Re: Save your environment
Dan,F6FLU wrote: ↑10 Nov 2020, 13:41 Hello,
Not at this time has such a feature been included with Log4OM V2. If you do a search on the Forum you will find that it has been discussed quite a bit and another OM came up with an APP that does hold window positions and apparently works quite well.
You could also do a search of the Feature Suggestions portion of the Forum and see about such suggestions. If they don't mirror what you are seeking ... then add that suggestion in that portion of the Forum.
ah OK
Thanks for these informations
ah OK
Dan - F6FLU
https://F6FLU.org
https://F6FLU.org
Dan,
Not seen any followups from you yet, but did pull URL/Link below from an OM's post in the Log4OM Feature section.
This is the APP I commented that is being used by other OM's seeking a solution to window positioning.
I've never used the APP so cannot speak to how good/bad it may/may not be. That would be up to you.
http://www.desksoft.com/WindowManager.htm
Thanks for this link
I’ll see that perhaps a solution...
Thanks again
Dan
Thanks again
Dan
Dan - F6FLU
https://F6FLU.org
https://F6FLU.org
