I have looked through the settings and cant find this, it may not be a current setting.....
I have noticed that this version updates solar activity and myriad other things very frequently. Far too frequently for my personal liking. Is there a setting where I can change the frequency of this, and if not, can it be added to a future version please.
John
Version 2.10.0.0 question
Re: Version 2.10.0.0 question
John,VK7XX wrote: ↑30 Nov 2020, 02:16 I have looked through the settings and cant find this, it may not be a current setting.....
John
Go to: Settings / Program Configuration / Program Scheduler
The system processes are listed in the left column. Click on the one(s) you want to adjust and make the changes. Tap the diskette image to save and also tap Save and Apply. Restarting Log4OM will also help re-orient things.
Hope this helps.
- VK7XX
- Old Man
KI5IO wrote: ↑30 Nov 2020, 03:54John,VK7XX wrote: ↑30 Nov 2020, 02:16 I have looked through the settings and cant find this, it may not be a current setting.....
John
Hope this helps.
Mate, that helps HEAPS !!!!! thank you from myself and from Norm, VK7AC whom I am guiding on 2 metres as I type this .......
Regards
John
After reading this thread, I thought I would like to adjust them myself. I would like to run on startup only, but cannot do this as far as I can see.
Is it possible?
Cheers
Is it possible?
Cheers
