I have now imported my ADIF files into Log4OM
In the Log there are some indications that some items where CHANGED FROM ? TO
But there is no indication of what it was changed TO ??
Is the explanation it being truncated
WARNING: Callsign: IL7G Date: 30/05/2009 17:36:00 Band: 20m Mode: SSB QSO STATE CHANGED FROM IT TO
WARNING: Callsign: IL7G Date: 01/06/2009 11:19:00 Band: 10m Mode: SSB QSO STATE CHANGED FROM IT TO
WARNING: Callsign: IL7G Date: 01/06/2009 12:33:00 Band: 12m Mode: SSB QSO STATE CHANGED FROM IT TO
WARNING: Callsign: YN2ET Date: 28/03/2011 21:35:00 Band: 17m Mode: SSB QSO STATE CHANGED FROM TX TO
WARNING: Callsign: YV5EAH Date: 24/04/2011 20:51:00 Band: 17m Mode: SSB QSO STATE CHANGED FROM FL TO
WARNING: Callsign: HB3YMM Date: 26/05/2011 18:59:00 Band: 10m Mode: SSB QSO STATE CHANGED FROM CH TO
WARNING: Callsign: CX7CO Date: 23/01/2012 16:27:00 Band: 10m Mode: SSB QSO STATE CHANGED FROM MV TO
WARNING: Callsign: R120K Date: 21/05/2015 07:07:00 Band: 10m Mode: DATA QSO STATE CHANGED FROM RU TO
WARNING: Callsign: HS0ZIQ Date: 03/03/2009 17:06:00 Band: 20m Mode: SSB QSO STATE CHANGED FROM - TO
Many Thanks... 73 Dave
Import ADIF Files ~ WARNINGS
Windows 10 Pro & LOG4OM - V2.29.0
Re: Import ADIF Files ~ WARNINGS
Hello Dave,
i think that this are entries which have state settet at HamQTH or qrz.com. All of this have no states
so i think that Log4OM has eliminated this wrong entries to nothing. As example, for the IL Stations
IT should be the country but not a state and i think Log4OM has deleted the wrong "state".
My idea without a test (i´m at work).
Hi Juergen,DF5WW wrote: ↑01 Mar 2021, 05:46 Hello Dave,
O.K... I can send adif if you want to test it at some point..??
I will look at the records to see if I can see something
73 Dave
Those countries worked are not ones that would have a state noted in the state field as the USA would. Seems the incoming ADIF had bogus info in the state field, inspecting the ADIF import is reccommended
Thanks...
I looked at a couple, it looks like the "bogus" data is in QRZ,
The IL7G & CX7 have IT & MV in their address details
Given the age of these QSO's I'm 99.9% certain I was using HRD
It appears the message: STATE CHANGED FROM "something" TO
Is correct.. It appears they are now "BLANK", deleted
YN2ET appears to have an address in Texas, TX and YV5EAH in Florida, FL
HB3YMM as ch in address line
HS0ZIQ as - - in address line
During looking at this issue I discovered another "State" Anomaly..??
To avoid confusion on this post, will post another topic.
Thanks.. 73 Dave
