Is it possible for Log4om2 to change mode to USB-D to use with WSJT-X?
If so, how is it done?
Best Wishes
Brian G0VAX
USB-D on Icom radio
Re: USB-D on Icom radio
If you set it up as described in our user manual and using Omnirig select the Icom ini file for your radio marked DATA then when you change band in WSJT the mode of your radio will change to USB-D
Dont know what Icom radio you have but I know from personal experience that this works with all late Icom radios 7300, 7600, 7610, 7700, 7800 etc
Hi Terry,G4POP wrote: ↑12 Oct 2021, 12:43 If you set it up as described in our user manual and using Omnirig select the Icom ini file for your radio marked DATA then when you change band in WSJT the mode of your radio will change to USB-D
Thank you for the quick reply. I have the ICOM IC-756 Pro 3
Best Wishes
Brian G0VAX
Not sure if there is a data ini for the Pro3 if not you will need to edit the ini file
