Add/Remove fields from the QSO box?
n7tat
Post by n7tat »
Can the upper left edit pane (gray with callsign, RST, etc) be edited to add or remove fields? It has fields I don't want and is missing some I do want.
Re: Add/Remove fields from the QSO box?
No, thats stored in the main UI. The QSO Window shows all important qso data. All others you´ll
find in the Info tab and/or in the award tab.
