2.21.1 WKD BEFORE and sat op.
I2OIM
Post by I2OIM »
There are a bunch of problem using LOG4OM with satellites in digital modes, and a new one appears with this new version.
When I'm looking for info about a call, the frequence is read via CAT but the log reports the right frequence I worked (i.e. the rig transmit over 432, but I'm workinkg QO-100 with upconverter and receiving with a SDR dongle on 13 and 3cm).
Until 2.21.0 if I click WKD BEFORE I read the list of qso with that station.
With 2.21.1 the click shows nothing, I suppose the reason is that the qso was done on the 13cm band (receiving at 3cm) and the CAT read 70cm.
The older problem are that I need to log some information coming from WSJT-X (frequences, rst, qth) and some other from Log4OM (antenna, rig, prop, sat name, sat flag, sat mode) and this seems impossible (I can't find a way). This requires I edit any single QSO after I log it, but this has a solution: the void WKD BEFORE hasn't, so I went back to 2.21.0
Pietro I2OIM
BTW: why I can't post on the national forum (IT)?
