Hey folks,
I'm just getting back into amateur radio after a 5 year hiatus (only operated for about 3 months even then).
So I'm looking at a couple different options for logging.
#1 Question currently: Does Log4OM support sending CW via a single USB cable into my Yaesu FTDX-10? I've been able to get HRD and N3FJP to work. There are two com ports.. one for cat control and the other for the DTR sending.
I look forward to hearing from you and I'm sorry for the newbie question.
Tom - NT4TC
New user, legally blind and have a question or two
Re: New user, legally blind and have a question or two
Sorry for the delay I have been unwell and its slowed me down a lot.
No CW via separate USB is on our list
However we do support USB Winkeyer by K1EL if you have one
Thank you Terry. I hope you're feeling better.
2nd question... If I choose 'Contest' input...
1. Can I control what fields are visible for input?
2. Can I control the order in which they're tabbed through? (do i just put them in that order?)
3. Does that create a separate log or just use my master log?
(well I guess that was the 2nd, 3rd and 4th questions)
Tom - NT4TC
Tom - NT4TC
Tom
1. No
2. No
3. You can use a seperate log if you like but it's not neccessary because log4om will show worked before only for stations worked in the contest if you use the main log
1. No
2. No
