I Have a weird problem. If I double click on a station in the cluster view the set automatically goes to the frequency of that station. This works well but lately i have noticed that the frequency is off. EG the cluster frequency is 7112 ant the set goes to 7113.30. If i double click again it goes to 7112.
Log4om 2.22
Ominirig
FT991A
Anyone else experience this behavior? Any solutions?
73 PA5MR
Wrong frequency when double click in cluster
Re: Wrong frequency when double click in cluster
Mario,pa5mr wrote: ↑26 May 2022, 15:45 I Have a weird problem. If I double click on a station in the cluster view the set automatically goes to the frequency of that station. This works well but lately i have noticed that the frequency is off. EG the cluster frequency is 7112 ant the set goes to 7113.30. If i double click again it goes to 7112.
Log4om 2.22
Ominirig
FT991A
73 PA5MR
Check your Configuration / CAT setup. It is possible that you have turned on the offset.
- CAT-omnirig-medium.JPG (62.25 KiB) Viewed 1120 times
I have the same issue on the latest stable version Log4OM with FT-991A. Sometimes is frequency shifted on TRX after double-click in cluster. Offset in CAT configuration is turned off.
Try selecting 'Send mode before frequency to radio' in settings/program config/CAT Interface menu
