Hallo zusammen,
ich versuche das DX Cluster Plugin von SDR Uno mit dem Cluster Server von Log4OM zu connecten.
Auf den Clusterserver kann ich mich connecten, aber das Cluster Plugin bekommt keine Datensätze.
Das Cluster Plugin erwartet einen Responsestring, bei öffentlichen Clustern ist das meistens mein Rufzeichen.
Ich habe schon alles mögliche versucht, was putty mir zurückgibt, aber es kommt nix rüber.
Hat hier jemand eine Idee?
Gruß
Thomas DG6UAX
Cluster Server und SDRuno DX Cluster Plugin
Moderator: DF5WW
Re: Cluster Server und SDRuno DX Cluster Plugin
Log4OM cluster server is port 7300 localhost or 127.0.0.1
On Log4OM side everything works as expected, other cluster clients as in SDR Console as example work perfect with the local cluster server. Problem is the SDRUNO DX Cluster plugin - it connects, but does not show any data in the spectrum.
I have switched to SDR Console.
73 Thomas DG6UAX
73 Thomas DG6UAX
Did you ask SDRUNO for advice?DG6UAX wrote: ↑28 Mar 2021, 08:25 On Log4OM side everything works as expected, other cluster clients as in SDR Console as example work perfect with the local cluster server. Problem is the SDRUNO DX Cluster plugin - it connects, but does not show any data in the spectrum.
73 Thomas DG6UAX
I asked for advice in the SDRplay groups.io group, but did not get an answer yet.
Will look for other forums
Try direct to SDRPLAY they are very responsive
I´ve created a support ticket at SDRPlay - we´ll see
SDRplay have solved the problem and send me a beta release of the DX cluster plugin. It works perfect with the internal cluster server now. Hope they release it soon for the community.
Thomas
Thomas
Thomas,
Great input and thanks for follow-up.
