Modes category
M0QVE
Modes category
Post by M0QVE » 03 Feb 2020, 22:58
Don't you think by moving FT-4 and FT-8 from phone mode to digital. It would look better on the cluster? But this is just mine opinion...
Re: Modes category
Post by KD0ZV » 03 Feb 2020, 23:22
Its not as black and white as you think and nearly impossible to categorize perfectly. The logging program has no way of knowing what every mode is.
There is a setting in Log4OM that allows you to control what band segments are what mode and overwrite FT8, etc for common FT8 frequencies but for the life of me I cant remember where its at.
Maybe someone will chime in with where that is and if I find it, I will post back.
Re: Modes category
Post by KD0ZV » 03 Feb 2020, 23:48
There is an XML file in your user settings folder user\appdata\roaming\log4om2
I think Doug told me that something else plays into this so as I said above hopefully they will chime in.
Good luck :)
PA1WBU
Re: Modes category
Post by PA1WBU » 13 Feb 2020, 19:10
M0QVE wrote:
03 Feb 2020, 22:58
And mine ;-)
Re: Modes category
Post by DF5WW » 13 Feb 2020, 20:02
Your´s ? ... Simple, check out your settings for the region. PA is in region 1 as DL too. If there´s another
bandplan in PA active then in the rest of the R1 region we can have a bandplan for a special DXCC like
bandplan_dxcc263.xml ... (PA). If no one exist you can do any changes in bandplan_r1.xml and save it as the dxcc
bandplan. This "user" related bandplans will not be overwritten with a new L4O update. That´s the way
you can use ...
73´s .. Juergen ... ALT-512 SDR (10W) , 50 m random wire at CG-3000 autotuner ...
PA1WBU
Re: Modes category
Post by PA1WBU » 13 Feb 2020, 20:34
You just beat me to it, I just found the XML config files. I need to carefully check what / how to change it to get the desired result.
