JTDX and JTAlert software pack, the call from the logged station will remain in the Callsign field from log4om. The call remove in JTDX. I must remove manuel the call in log4om with press the red X. Without JT_Message, the callsign field remains empty but you also get no information about the station. Perhaps it is possible with modification that this is possible in combination. Have always been use N3FJP and it worked there maybe also possible with some adjustments.
regards,
Pat
Clear Callsign JTALERT
Re: Clear Callsign JTALERT
JTAlert use a service of V2 that is able to show callsign from external sources.
There is not yet a service to be called to clean up calls.
In JTAlert there is a re-broadcast function that sends received messages to Log4OM. This include the "callsign" and the "clear" event from WSJT-x and JTDX
Upcoming 2.3.0.0 will be able to read both of them, so you can eventually disable the "set callsign" in JTAlert and use the re-broadcast function to a JT message UDP listener set in Log4OM (rebroadcast is available in WSJT/JTDX application settings menu in JT Alert.
I install the new version 2.3 and now it works after qso logged, the callsign field is emptied.
