Saved filter in Recent QSO's folder
iw0gpw
Post by iw0gpw »
Hi everybody,
in the Recent QSO's folder we can save and activate/deactivate the "standard fields" filter only.
It would be fine to save all kind of filters (references, my references and confirmations) and act/deact them all togheter
tnx es 73
de iw0gpw - Antonio
NR3E
Re: Saved filter in Recent QSO's folder
Post by NR3E »
Antonio,
I think I read somewhere in this forum that saved filters will be coming in a future upgrade. In the meantime, I have found a workaround. I created a text file on my desktop and have the syntax of several filters saved there. I simply copy the one that I want and paste it into the filter screen. I use the Custom Query function as it is allows for copy and paste and is more flexible.
Here is a sample of some of my my saved filters. The first column tells me what it does and the second column is the syntax.
SOTA S2S ContactReferences LIKE "%SOTA%" and MyReferences LIKE "%SOTA%"
SOTA Chaser ContactReferences LIKE "%SOTA%"
SOTA Activator MyReferences LIKE "%SOTA%"
Until the upgrade comes along with saved filters, this workaround does save some time.
Hope it helps,
Ron, KI4TN
i'm working on it
