Cluster window on Main UI Screen
VK4FI
Post by VK4FI »
Good Morning,
Firstly thanks for an great program, I have been a longtime user of V1 and am now running V2, and it is certainly a great improvement, not that V1 was no good.
One thing I would like to see is the ability to replace the Band map on the main UI that was introduced in V 2.7.0.0 with a cluster window, similar to the one in V1 as shown in the attachment.
I know that you can open up a cluster as a separate window, but I really did like and use all the time, the cluster window that was docked on the main UI in V1.
Thanks again for a great program and thanks for considering this request.
Cluster Window.jpg (109.95 KiB) Viewed 2617 times
________________________
Steven Dudley
VK4FI
Highfields Queensland AUSTRALIA
Royal Australian Corps of Signals (Retired)
"Certa Cito"
Re: Cluster window on Main UI Screen
Hi Steven,
that's something i would like to have too.
Unfortunately space on the main UI is not so abundant, so i think i should add this as an alternative to the band map tool (maybe in a tab control)
VK4FI
Post by VK4FI »
Hi Daniele,
Yes that is exactly what I was after, in V2 there is an option to turn the band map on or off using the icon at the bottom right of the screen, it would be good to have the option of either the band map displaying or the cluster displaying and the ability to filer the cluster exactly the same as in V1. That would be truly excellent. Hope you are able to make this happen as soon as time permits. It will make an already great program even better.
Steven Dudley
VK4FI
"Certa Cito"
