Would it be possible to add a LoTW filter to the Cluster tab filter options to only display LoTW participating stations?
Thanks.
Vince, VA3VF
LoTW Cluster tab filter.
Re: LoTW Cluster tab filter.
I am fairly sure there is a cluster command that you can send to your chosen cluster server for that, something like a show only command.
Check the filter guide for dxspider or better still use VE7CC and the CC user software to exclude all except LOTW users
I use VE7CC, and to the best of my 'guess', the LoTW filter is local to CCUser, not sent to the server like some other filter options.
73 de Vince, VA3VF
73 de Vince, VA3VF
