Good evening,
Thank you for your very good work, I have a little suggestion.
Would it be possible to have the log in a mysql database on a remote server and at the same time in a sqlite database in a local file?
friendly
Log in mysql database on server and in sqllite on local PC ?
Re: Log in mysql database on server and in sqllite on local PC ?
Why not use mysql for both?
Is it possible to have 2 databases in log4OM or do you have to make a replica?
Have as many databases as you wish
I believe what you are asking is can you have a MYSQL and Sqlite database at the same time containing the same data and synced automatically. If that is your question, then no. They are two different database systems and I know of no way to make them work together.
You could have both, but you could only be connected to one at a time with Log4OM.
Doug
W7DRM
Doug
W7DRM
