2ND OPERATOR LOG
2ND OPERATOR LOG
My wife has her ham license. It would be great if there was an operator button that would switch between her database and mine. She needs to know when there is a country she hasn't worked.
Re: 2ND OPERATOR LOG
Set up another configuration and database for your wife then just change configuration when she needs to use the computer
My wife has her license, so I set up a portable version of Log4OM for her. That way, both logs can be running at the same time, if need be. I have never tried having her log using CAT control at the same time as mine (isn't usually needed here), so that might be a problem.
Jim N6VH
PS - I just brought her log on line, and was able to have it connect to CAT at the same time my log was connected. Seems to work OK.
Jim N6VH
