WAS checking
WA2SQQ
WAS checking
Post by WA2SQQ »
First thanks so much for adding the “state” field on the DX cluster.
Would it be possible to have LOG4OM check states the way it check countries, to alert you when a new state is spotted?
CT1BXX
Re: WAS checking
Post by CT1BXX »
Hi Robert,
It is an excellent idea. :idea:
I had already thought the same, because many years ago, and before using Log4OM, I used a Logbook that had this possibility and was an easy way to check what was missing.
I believe that the current inclusion of the state in the spots, will end with this indication, at least it is my hope, but time will tell. :)
73 Manuel Fernando CT1BXX
