Enhancement ideas
G4DWV
Enhancement ideas
Post by G4DWV »
Just a couple of thoughts about the UI.
I would like to be able to have a given tab in the F6 > F10 open by default
I would also like to be able to rearrange the tabs. For example, I think the recent QSOs and worked before tabs should be next to each other.
I do not know if it is possible, but I would like to be able to assign colours to log entries. For example, a friend of mine and I were in an Olivia QSO and we were joined by another amateur. Though I have made a note that we were in a net together, being able to colour the other two amateurs' entries the same colour would make that obvious. There could even be a colour indicating that there is an entry in the worked before tab making it unnecessary to manually check. The possibilities for this enhancement are quite exciting.
Cheers
Guy
