I produced a test sheet and I did not like the way that it looked. The main gripe was that the callsign of the other station was too low in that it was not level with the base of the "... cfm qso:" line. Also, it is shifted too far to the right.
So, I go to the manual to see how to adjust this and find that the test sheet in the manual is the same as mine with respect to the callsign position.
My suggestion is that the label printing feature be given more options to edit and design the labels. If the default values are held in either the registry or an ini file I would be happy editing them there.
Stay safe.
UPDATE:- Found this https://forum.log4om.com/viewtopic.php?t=49 from 2013. The 'label designer' in Log4OM is a misnomer. It should be 'select or make a template'.
Label Printing
Label Printing
